Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
Starting Issue
Old Sep 9, 2019 | 06:38 AM
Scotty7375's Avatar
Icon5 Starting Issue
I know this appears to be a Ruckus forum but, I seem to be chasing my tail. I have a 02 Metropolitan I acquired for $100. Turn the key on the headlight goes on and off, hit the start button and the relay just clicks. I can bypass the relay and it turns over but, no spark or fuel pump. I replaced the starter relay and main relay and still have the same issue. I have also replaced the ECM. What am I missing????
Old Sep 11, 2019 | 06:26 AM
rchid's Avatar
Default Re: Starting Issue
On my thread someone had mentioned the brake switch is also an important part for starting the motor. I'm looking to buy one for my starting issue to see if it works for me.
Old Sep 11, 2019 | 03:11 PM
MyTYPES's Avatar
You're going a little overboard here. Why the ECU? Try getting it running before that. Clutch switch, ignition switch Comes to mind. Usually when they fail it's not all at once, It's intermittent You can jump the clutch (I'm assuming it's a stick?) It's two wires normally on/off simple. You did not specify if you had the lights on while attempting to start? Bottom line: IGNITION SWITCH! You can also jump the solenoid at connections and if it cranks you know your good there. (have key on the damn thing just might start).
spens 91 Ef
Jun 17, 2015 12:25 PM
Taimaishuuyo
Apr 28, 2012 07:57 PM
bigjefft
Apr 22, 2012 12:24 AM
sawedoffcoupe
19
Aug 28, 2007 11:10 AM
shreddinryguy
Jun 26, 2005 02:03 PM
