12v accessory spot on fuse box? 98 RS.
Old Sep 8, 2019 | 04:11 PM
B_Swapped93's Avatar
Default 12v accessory spot on fuse box? 98 RS.
Wiring up my wideband and 3port boost solenoid, having trouble finding where the 12v accessory spot is on the fuse box under the dash. I've included a pic
Old Sep 8, 2019 | 04:37 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 12v accessory spot on fuse box? 98 RS.
Option connectors cavities:
Old Sep 8, 2019 | 07:34 PM
Awesome, thank you! couldn't find that list anywhere. So to power my wideband and boost solenoid, i'd want to use Option:3 ACC?
Old Sep 8, 2019 | 08:27 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Option 3: ACC will provide 12V power when the ignition switch is in the ACC or ON positions. (This terminal is protected by under-dash Fuse No. 28 (10A).)
Option 4: IG2 will provide 12V power when the ignition switch is in the ON position. (This terminal is protected by under-dash Fuse No. 17 (7.5A).)
You can use either of these terminals; however, Option 3 allows power in the ACC position too. With either of these, you should still using an in-line fuse, the fuse amperage would be based on what the parts manufacturer recommends.
Another option would be to use something like a Littelfuse Add-A-Circuit at other existing fuse slots, instead of at those Option Connector terminals.
Old Sep 9, 2019 | 08:32 AM
Thanks again! was dreading wiring these up off a distribution block.
hopefully the keywords used will help others, if they come across it.
Old Sep 11, 2019 | 03:03 AM
NVturbo's Avatar
O.G. triple O.G.
If you grab some of these connectors from 90-93 Accords (driver side door), they fit perfectly in those slots.
Old Sep 11, 2019 | 07:43 AM
tony_2018's Avatar
Fish Twig
Might have to do this, can't figure out why the radio keeps dying...
skyviewLA01
Jul 22, 2017 09:43 AM
misledyouth_is_back
Dec 30, 2003 02:59 PM
