2 wheel or 4 wheel alignment after coilovers
Old Sep 6, 2019 | 08:36 PM
Spaceturtle917's Avatar
Default 2 wheel or 4 wheel alignment after coilovers
I just installed progress cs-2s on my 1996 CX Hatch. I'm well aware that I need an alignment but do I need a 4 wheel alignment or is a 2 wheel alignment fine? Do the 6g civic even have rear toe adjustment? Will coilovers affect my rear toe? Should I do 4 wheel alignment anyways I case my rear toe is out of spec?
Old Sep 6, 2019 | 08:59 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 2 wheel or 4 wheel alignment after coilovers
You should ALWAYS do a 4-wheel alignment on a vehicle that has independent front and rear suspension. Two wheel alignments are for vehicles with solid/live rear axles. Toe is not your only concern... camber is most affected by lowering the vehicle and it should be checked. There is limited adjustment from the factory, and this is why adjustable camber kits are produced and sold for these applications.
Old Sep 7, 2019 | 03:08 AM
https://honda-tech.com/forums/suspen...-kits-2614449/
This is literally stickied under the suspension forum.
Old Sep 7, 2019 | 07:36 AM
tony_2018's Avatar
Fish Twig
4 wheel....
Feb 24, 2019 08:58 PM
vtecnique69
Honda Civic (2006 - 2015)
Apr 21, 2013 08:42 AM
h22 civic
Suspension & Brakes
Jun 11, 2005 05:44 AM
nygunrunners
Nov 3, 2004 03:54 PM
