Hey guys, picked up a 92 EX as a beater. Was checking condition of the valvetrain and when replacing the valve cover bolt on the bottom left side of the engine (if viewing it from the front of the open hood) I went a little too hard and snapped it off. Picture shows where. Am I totally screwed or is there a way to fix this?
those bolts only require less than 10ft lbs of torque. People using gorilla strength to tighten them and this is the end result. A bolt extractor kit is your best option. Make sure to not leave any metal shavings or you'll have more issues.
