Honda CR-V & Element 2WD & 4WD Element & CR-V
Is my immobilizer working?
Old Sep 2, 2019 | 01:39 PM
kalfirst's Avatar
5 Year Member
Default Is my immobilizer working?
Hello guys and gals,
I recently purchased a 2004 CR-V EX-L and go two keys and no remotes. One key looks like original Honda key and the other is not and when I put the key in the ignition I get that green key indicator. . Yesterday I was looking at wiring a GPS tracking device and shorted something while messing with the wires and blew a fuse. The car started fine but the green key indicator did not appear, the radio did not work and the power door locks opened with the door buttons but did not close. Today I drove to a hardware store purchased fuses and replaced the a 10Amp fuse under the hood and everything back to normal. The question is, does that mean my immobilizer has been disconnected or bypassed?
Thanks
Old Sep 2, 2019 | 04:22 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Is my immobilizer working?
You blew the back-up fuse.
The Immobilizer wouldn't be bypassed or disconnected due to a blown fuse.
Old Sep 2, 2019 | 06:17 PM
kalfirst's Avatar
5 Year Member
Thanks tech8. That was my point and question. Since a blown fuse would not disable the immobilizer does that mean:
1- The immobilizer functioned properly and the car started because I had the proper key and the indicator not coming on is just that.
Or
2- The car shouldn't have started because the indicator didn't come on meaning the immobilizer couldn't function without the fuse and that the car started meant that the immobilizer has been disconnected/bypassed before I purchased the car.
Thanks
Old Sep 2, 2019 | 07:14 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Or
Thanks
#1; but, only in part.
The immobilizer functioned properly and the car started because you had the proper key. The indicator in the gauge did not come on because under-hood Fuse No. 9 (10A) was blown and no power (+) was supplied to the indicator bulb. Under-hood Fuse No. 9 also supplies power to the Immobilizer Control Unit Receiver; but, that is not the only source of power.
The immobilizer system consists of the ignition key, immobilizer control unit-receiver, immobilizer system indicator, PGM-FI main relays, fuel pump and the ECM/PCM. With the ignition switch in ON (II) or START (III),the immobilizer control unit-receiver and the ECM/PCM receive an “ignition on” signal through Under-hood Fuse No. 6 (15A) and the PGM-FI main relay 1. The ECM/PCM then sends power to the ignition key transponder through the immobilizer control unit-receiver. The transponder then sends a coded signal back to the ECM/PCM through the receiver.If the signal is correct, the ECM/PCM will energize the car’s fuel supply system by grounding the PGM-FI main relay 2.
Old Sep 2, 2019 | 07:25 PM
kalfirst's Avatar
5 Year Member
Perfect. Thanks a lot.
Swatkins
May 1, 2013 12:30 PM
Wicked13
May 22, 2012 03:24 AM
single_slam
Mar 6, 2012 10:34 PM
jermo
Mar 11, 2011 09:41 AM
SKY350
Acura TSX
Jan 19, 2010 04:44 PM
