Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
2008 honda ruckus fuel pump went out. Bought new pump,but it won't come on.
Old Aug 31, 2019 | 10:19 AM
madmark's Avatar
Default 2008 honda ruckus fuel pump went out. Bought new pump,but it won't come on.
My fuel pump went out. I bought a new one from honda dealership,but it won't come on. I'm getting positive pulse current to pump,but still won't come on. Honda tested pump and said its good. Relays are good. Any advice?
Old Sep 11, 2019 | 06:43 AM
rchid's Avatar
Default Re: 2008 honda ruckus fuel pump went out. Bought new pump,but it won't come on.
I say test it on a friend's scooter if thats available to see if if it works on that. If so then check your main relay on the positive terminal.
Old Feb 16, 2020 | 05:06 AM
capttony58's Avatar
I’m having the same problem. New pumps (2!) and they will not deliver fuel. Relays are good, getting current to the pump, new fuel filter, no restriction in the fuel lines, but it will not deliver the fuel up the hose to the carb. Help!
Old Mar 27, 2024 | 09:10 AM
David Masiello's Avatar
Did you ever figure it out
Old Mar 27, 2024 | 09:11 AM
Did you ever find out the issue
gondwana1
Honda CR-V & Element
May 9, 2012 11:36 PM
dodge
Jan 14, 2002 09:29 AM
apexii
Aug 7, 2001 01:07 PM
