H swap build
Old Aug 28, 2019 | 10:09 AM
Accordfan2000's Avatar
Default H swap build
All while trying to fix my cars fuel issues, I'm building a replacement h22a to swap the A4 out. Was considering using an f20b DOHC vtec head, thoughts? Any advice would help
Old Aug 28, 2019 | 12:38 PM
Aradin's Avatar
Premium Member
Default Re: H swap build
F20B head has smaller combustion chamber and intake valves. Stick with an H22 head if possible.
Old Aug 28, 2019 | 01:09 PM
Thanks for the info. I've been trying to find an affordable h22 p13 head that complete
Old Aug 28, 2019 | 07:06 PM
Aradin's Avatar
Premium Member
F20B head will work if you have no other options and it's a stock-ish rebuild. Just wouldn't recommend it for anything serious on an H22 block. You can use a PDE head which is a better version of the P13 head but they are a little more rare and probably expensive.
Old Aug 29, 2019 | 05:01 PM
I am not planning on boost. The pistons I have a 11-1 compression, thought maybe the f20 head would help lower that just a tad. I'm going all on hear say. Im learning as I go with my car. First time building or fixing anything.
Old Aug 29, 2019 | 07:06 PM
Aradin's Avatar
Premium Member
11:1 compression is a non-issue for boost, fyi. Also it would be the opposite of your thinking. Smaller combustion chamber of the F20B head = more compression.
Old Aug 30, 2019 | 05:06 AM
I see what you are saying. It would squeeze the air even tighter before combustion. For the time being it might be my only option. A buddy of mine is helping me out by giving the head to me. My wife and I are on a very tight budget
radsman
Feb 28, 2011 06:10 PM
VietCloud7
Mar 22, 2008 09:04 AM
Acidcrakker
Nov 9, 2007 07:53 AM
Ef9Hatch90
Dec 17, 2005 05:53 PM
lodown414
Jun 6, 2002 03:13 PM
