2000 dx hatch automatic d16y7 i want to put d16y8 vtec obd2A manuel
Old Aug 25, 2019 | 03:19 PM
DaNiel Jr's Avatar
Default 2000 dx hatch automatic d16y7 i want to put d16y8 vtec obd2A manuel
hello world , i have a 2000 honda civic hatch automatic dx with obd2B d16y7 non vtec and i want to instal my d16y8 vtec obd2A manuel.. i took all the parts from a 1997 civic SI manuel coupe.. i swap automatic to manuel non vtec to vtec and obd2B to obd2A and its a headace let me tell ya loll. i have obd2B car but i have the ecu and harness from obd2A that i want to instal in.. my question is, theres a dash plug or cabin harness on my car ecu and i dont know what to do to match it with my obd2A harness and ecu so everything works because im gonna have an 4th plug un used from the car.. i know im gonna have issues with fuel pump and more things i dont even know.. cuz when i unplug plug A from original ecu the pump dont prime (Plug A from obd2b) on shematic picturez i found on internet..please let me know wats the best idea to make it work.. i need some enlightment before i start doing my swap.. u guyz know how it is... we are in the same boat
Old Aug 25, 2019 | 04:45 PM
tony_2018's Avatar
Fish Twig
Default Re: 2000 dx hatch automatic d16y7 i want to put d16y8 vtec obd2A manuel
obd2a and obd2b are different, that is your problem. You need to
a) get the correct ex harness from a 2000 civic ex 5spd
b) use your original harness and reroute wires and add vtect wires.
you have other things you'll need to do as well so please consult the 5spd swap thread. Should be located in the FAQ section.
Old Aug 25, 2019 | 07:12 PM
DaNiel Jr's Avatar
my choice would be (b) so i can take the original automatic ecu to converse it to manuel 5spd vtec by adding wires to the harness i have in the car? i have to change location of some wires in the harness is that it.. do you have an idea witch plugs in the harness .. like what figure i should be related to please i dont know i should figured out
Old Aug 25, 2019 | 07:51 PM
DaNiel Jr's Avatar
so adapt my motor for obd2B instead of adapt my car to obd2A relocate B6,B15, B23 change the 3wire iac plug for a 2 wire and add vtec pressure switch plus solenoide wire, and is the knock sensor on my 4th plug as the automatic configuration has a couple wires i could use.. i could ask the dealer for that i guess but i think u guyz are more specialist then them loll
Old Aug 26, 2019 | 03:52 AM
DaNiel Jr's Avatar
so my iac from automatic as 3 wire i have to take the iac and cut the orange wire change the plug for a 2 wire plug also relocate B6, B15 and B23 then add the 2 wires for vtec pressure switch and vtec solenoide... is the knock sensor on my 4th plug or i have to do a new wire too
elton_23
Dec 7, 2012 01:42 PM
dc4b20
Oct 25, 2009 04:05 PM
Haz31203
May 4, 2008 06:18 PM
leftcoast
Aug 9, 2007 08:51 PM
