Fuel pump not priming
Old Aug 24, 2019 | 02:03 PM
Turbo_kid18's Avatar
Default Fuel pump not priming
Well here I am again with another fricken problem with my 1996 Acura integra (originally an ls with a gsr engine swap, also has an OBD1 swap). So some background info, after I swapped in the gsr engine I went for a drive a few weeks ago. Anyway I broke down, fuel pump went out. I replaced the fuel pump, still wouldn’t start, put in a new main relay and it still wouldn’t start. I found some loose wires at the positive terminal and that fixed my issue. Since then I moved to school and haven’t been around the car. I went home 2 days ago to take the car with me to school. I left to fill up on gas and I was leaking gas out of the fuel pump hole. I replaced the gasket. Then I primed the pump 3 times and when I went to prime it a 4 time it wouldn’t prime. I put a jump starter to the fuel pump and it works. Also the engine cranks, just won’t start. I checked fuses and found 2 blown fuses, I replaced those, still nothing. I changed the main relay again for ***** and giggles, still nothing. I inspected both of the main relays I have and they look fine. If anyone has a thought of what my problem is, I’m all ears.
Old Aug 24, 2019 | 07:52 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Fuel pump not priming
Sounds like a fuse burnt check all them again.
Old Aug 26, 2019 | 07:04 AM
TekBuDDy's Avatar
Double check the pump. Make sure the sock didn't fall off. This happened to me a few weeks ago. The car would crank and struggle to turn over.
Old Aug 27, 2019 | 11:36 AM
I’m pretty sure the sock didn’t fall off. The fuel pump isn’t priming at all
Old Aug 28, 2019 | 05:02 AM
aw614's Avatar
10 Year Member
Loved
Have you tried another ECU to eliminate that that as an issue?
wwolf771177
Mar 25, 2013 02:54 PM
rx_86
Apr 1, 2010 04:49 PM
Tizzakowack
Mar 8, 2009 02:37 PM
Unjockable
34
Mar 3, 2004 07:38 AM
s.khang
15
Dec 16, 2003 01:46 PM
