Code 16 on Hondata S300 w/ RDX injectors confused as to why one is 14.4ohms
Old Aug 24, 2019 | 10:20 AM
hatchizzle's Avatar
Default Code 16 on Hondata S300 w/ RDX injectors confused as to why one is 14.4ohms
have a 94 eg with a 98 jdm b18c and a obd2 GSR harness running a p28 with hondata v300 and RDX injectors. EVerything has been running great and seemingly out of nowhere ill get a random CEL after getting on it on the freeway for code 16. As soon as i clear it, its fine again. The RDX injectors are OEM honda, and were brand new with less than 2k miles on them. I have obd2 to RDX injector adapters which i wonder if these could be the issue. I checked all the connectors and they seem tight. How else could i track down the exact issue?
Old Aug 24, 2019 | 12:34 PM
TheShodan's Avatar
Moderator
Default re: Code 16 on Hondata S300 w/ RDX injectors confused as to why one is 14.4ohms
What exactly is a code 16? That would help
Old Aug 24, 2019 | 04:54 PM
hatchizzle's Avatar
Code 16 - Fuel injectors. I did some more digging, and found the RDX service manual which states the resistance for each injector should be 10-13ohms. 3 of mine are around 12.5ohms and 1 of them is 14.4ohms which i suspect is the culprit for this code. Pretty surprising that after 3 months this brand new injector from Acura would fail.
Old Aug 24, 2019 | 06:23 PM
TheShodan's Avatar
Moderator
I don't think it failed, if it showing that high ohms. I'd check your writing to, get a meter and start testing
MUGEN_EG95
Sep 3, 2008 08:57 PM
Metal Head
Sep 1, 2008 08:12 AM
SkIp_Civic_Ek6
Jan 17, 2007 07:37 PM
delux247
Jan 28, 2004 11:48 AM
Turbohatch
Sep 4, 2001 03:38 PM
