Exhaust problems
Old Aug 17, 2019 | 09:54 PM
Frank Balzer's Avatar
Default Exhaust problems
I've got a 97 GS-R. I put on a Yonaka catback (from an ls. This is the issue) a while ago and have been running a 1320 UEL header with the telescopic test pipe. Fit up and worked out pretty good, I was told that a 4-2-1 header would be better to run. Also found out the UEL header can cause some issues down the road and it can take a small hit on the power of the car? Either way I bought a DC Sports 4-2-1 header and went to install and saw that my b pipe isn't long enough to reach the test pipe. The test pipe is also too big in diameter for the b pipe to fit into and mate correctly. I've been searching around and have seen people talk about a difference between 94-99 GS-Rs and other models of Integra, I know that there is a difference in the catback length, I'm just not sure the exact difference is and what to do about the predicament that I'm in here. Please help, I don't want to go out and buy the wrong test pipe and have that fall too short as well.
Thanks.
XLR8 GS-R
Welding / Fabrication
Dec 24, 2006 12:37 PM
DC2_2
Nov 25, 2006 09:36 PM
smkngsr
May 18, 2005 07:42 PM
ludermark
Sep 14, 2004 09:07 PM
