Many happy years Honda Jazz (Fit) Driver
Hello happy drivers,
I am Bert from The Netherlands and i have a Jazz since 2007. Never had problems so far only now i have a orange ABS warning.
It says a fault in the ABS pomp relais.
Enyone knows this issue?
Thanks.
Thanks.
Most likely there is an underlying problem causing the ABS fault. Is there a check Engine Light illuminated? Either way you will need to have the car scanned to detect any faults. You can start by using your own scanner or perhaps stopping into a local car parts store (Like Autozone in the US). Otherwise you may need to go to a dealer for a more comprehensive scan.
