1994 EG b16 power steering guide ?
Old Aug 15, 2019 | 08:20 PM
Logan Agustin's Avatar
Default 1994 EG b16 power steering guide ?
Does anyone have this set up? If so please tell me what I need to buy to have b16 swap in my EG with power steering? And if I still can use my d-series pump?
Old Aug 15, 2019 | 09:13 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 1994 EG b16 power steering guide ?
You cannot use your "D" series P/S pump on a "B" series VTEC engine. You will need a "B" series P/S pump... I believe one from a '94-97 Del Sol VTEC or Integra is the correct part.
Old Aug 15, 2019 | 10:59 PM
Thank you! How about the brackets? My head did not come with the b16 brackets
Old Aug 16, 2019 | 09:04 PM
JRCivic1's Avatar
10 Year Member
Community Builder
The upper P/S bracket should come from the "B" series VTEC engine that the pump comes from... the difference is the length of the adjustment bolt tab, so you want to match the two parts (bracket and pump). The lower P/S bracket is the same for all "B" series 1.6L - 1.8L engines... VTEC or non-VTEC.
mfisher1987
Jul 16, 2015 04:58 PM
Flite
Dec 5, 2006 02:59 PM
jdmmugeneg6
Jul 11, 2004 10:30 AM
HATCHingMN
May 30, 2004 08:08 PM
Dveloped
Jun 20, 2003 05:33 PM
