Flashing dash lights
06 odyssey. Been doing this for a couple weeks. Drives fine. Starts fine. I had autozone test the battery and alternator and both were good. Cleaned off all the corrosion on the negative. None on the positive. I also replaced the ground from the battery it was in pretty bad shape. I checked the grounds on both passenger side and driver side kick plates. Those looked good too. Not sure what to check next.
Dcmonstr_33
Jun 28, 2013 11:47 AM
