B16A High Mileage Rebuild - What to replace?
Old Aug 15, 2019 | 01:28 PM
eg6noise's Avatar
Default B16A High Mileage Rebuild - What to replace?
Hi, I'm currently in the process of gathering parts for a rebuild on my B16. The engine has 133k miles and will be rebuilt on a budget, but I will not cut any corners. Apart from the well-known parts list (bearings, gaskets, oversized pistons, water pump, belts and etc) what is common to fail or that needs replacement on a rebuild on these engines? I wonder what is the lifespan of some of the valvetrain components (springs, retainers, keepers), oil pump and if there is any other parts that need to be replaced on a rebuild (main cap bolts, cam cap bolts, any torque-to-yield bolts, etc)
Old Aug 17, 2019 | 03:06 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: B16A High Mileage Rebuild - What to replace?
Do you have a factory service manual? When disassembling, you can inspect everything against that and determine whether or not it should be replaced.
Old Aug 17, 2019 | 10:42 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Biggest pointer I could give you is bore it over to 81.5mm if it’s currently burning oil. Also the main cap bolts are fine and shouldn’t need replaced.
Old Aug 17, 2019 | 01:16 PM
eg6noise's Avatar
Yes, I do have the FSM, can't live without it! Unfortunately there is some test procedures missing: There isn't a way to test valve springs, no mention of replacing/verifying head bolts, main/cam cap bolts and other stuff. I just wanted to make sure if more experienced guys would have any tips and pointers that would save me from any troubles.
Old Aug 17, 2019 | 01:24 PM
eg6noise's Avatar
Thank you. The engine is indeed burning oil, and a compression test shows between 180-175. Oversized pistons were in the plans, but I was thinking to go .010" over instead of .020" to better conserve the sleeves for a potential forced induction application. Any specific reason to not even bother and go straight to 81.5mm as per your suggestion?
Old Aug 18, 2019 | 03:44 PM
Loved
Community Favorite
I would just got 81.5mm, there’s a larger variety of pistons at that size.
Old Aug 20, 2019 | 04:04 AM
JKaze's Avatar
10 Year Member
In those miles, cylinders have usually wear, so measure especially their roundness. Other one is exhaust valve guides.
Old Aug 20, 2019 | 02:38 PM
D21X's Avatar
Here's my bill of materials when I did my rebuild. Not sure if the parts are same as b16, but just to give you an idea.
File Type: xlsx
hybrid2007
Jan 31, 2008 10:29 AM
Pooby88
May 28, 2006 10:21 PM
itr1235
Mar 29, 2006 05:00 AM
flat-blk-HB
Feb 14, 2004 08:55 AM
