Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2012 Honda accord flashing lights check engine
Old Aug 14, 2019 | 03:42 PM
LaChiusa's Avatar
Default 2012 Honda accord flashing lights check engine
Coding u0155 lost communication
Battery replaced, alternator replaced .
2 Honda shops have looked at it
I have replaced the cluster recommended by the 1st honda shop.
I can drive it for 100 miles, or 10.....the check engine light comes on...ac shuts off the drive lights flashing, gauges flutter. Help
Old Aug 14, 2019 | 04:13 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2012 Honda accord flashing lights check engine
First check under-dash Fuse No. 15 (10A) and Driver's side under-dash Fuse No. 5 (7.5A).
Since the battery, alternator, and gauge control module has already been replaced, the problem can be in the F-CAN communication lines/wiring or connections that run from the gauge control module to the ECM/PCM. ECM/PCM is located next to the car battery; or even an issue with the ECM/PCM.
PRainey12
Jun 18, 2017 09:27 AM
khelm09
Honda CR-V & Element
Sep 20, 2013 06:09 PM
