Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Misfire Cylinder 1,2,3,&4 also random mifire
Old Aug 13, 2019 | 09:08 AM
medrano_santos's Avatar
Default Misfire Cylinder 1,2,3,&4 also random mifire
Already replaced the coils and spark plug, erased the codes. Then a few days later the random misfire code came back on again. What other option to figure out what could be the problem?
Old Aug 13, 2019 | 12:02 PM
civichxtreme2's Avatar
Default Re: Misfire Cylinder 1,2,3,&4 also random mifire
Check compression on all cylinders, check timing, Could be any number if things. Has the car been overheated at all?
Old Aug 13, 2019 | 12:58 PM
Yes it overheats when the car is still for certain amount of time, I wanna say about a good 30 minutes and then it'll start overheating. For example, if I'm stuck in traffic and my car hasn't been moving. The thermometer will start creeping up, I have changed the fans and the thermostat but it's still does the same thing.
Old Aug 14, 2019 | 05:47 AM
NDNV's Avatar
Check for a blown head gasket. Quite common in these engines.
Old Aug 14, 2019 | 07:30 AM
+2 on this, blown HG would explain a lot of your issues and as previous poster stated is super common with the D17 engine
Old Aug 15, 2019 | 04:54 PM
benchwarmer's Avatar
5 Year Member
Try an injector cleaner they may be dirty
bobinyelm
Aug 2, 2017 09:28 AM
KDvtec5757
Aug 16, 2008 10:51 AM
Kevin Cliff
May 5, 2004 04:17 PM
acqua20
Jul 16, 2002 07:52 PM
