Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Coolant temp gauge sensor location B-series
Old Aug 12, 2019 | 01:52 PM
Creator's Avatar
Default Coolant temp gauge sensor location B-series
Wondering where you guys have put a sensor for a coolant temp gauge. I wanted to put it in the thermostat housing. Plan was to put a "T" in where the current sensor is, but after looking at the 5 different adapters decided the housing wouldn't deal with all the extra weight during race conditions. I'm trying to be the least intrusive while still maintaining functionality.
Setup is a B18C1 head on B18B block.
Old Aug 12, 2019 | 03:28 PM
nannini's Avatar
Default Re: Coolant temp gauge sensor location B-series
I put mine on the upper radiator hose. It was easy and seems accurate.
Old Aug 12, 2019 | 03:41 PM
iwannarace's Avatar
x2 i got one of these. Worked fine.
jdmark1's Avatar
The B18B block already has a spot for a coolant temp sending unit. It's right in front of the coolant temp sensor and behind a water hose joint. Here's a picture with it circled in red:
Old Aug 12, 2019 | 05:50 PM
chuck chainz's Avatar
This is what I did on my B20.
Old Aug 13, 2019 | 04:31 AM
maxwellmercer's Avatar
Nice idea, Chuck!
Old Aug 13, 2019 | 05:30 AM
Dilbones's Avatar
Can also splice wire into the stock temp sensor...
Old Aug 13, 2019 | 07:36 AM
Didn’t notice the first post said B18C5, but the water neck should have a provision for coolant bleeding on it as well making it pretty easy to thread for an aftermarket coolant sensor.
Old Aug 13, 2019 | 08:41 AM
BlueTeg's Avatar
I have put mine coolant temp sending unit in the upper radiator hose on my B16a.
I picked up one of these from Hasport: https://hasport.com/store/index.php/...tem/egkha.html
and cut about 1 inch out of the upper radiator hose. Autometer sending unit threads right in to the Hasport hose adapter and I used an old fan switch sensor as the plug for the other hole in the Hasport hose adapter.
Old Aug 13, 2019 | 11:11 AM
90civichbsi's Avatar
I removed the thermostat housing bleeder and re-threaded the hole for my sensor. I use a filling funnel to bleed the cooling system from the cap so the stock bleeder isn't necessary.
Old Aug 13, 2019 | 01:38 PM
dirty19's Avatar
Ridin Dirty in Cali
Adapter in the upper hose like the others
Old Aug 14, 2019 | 08:49 AM
Creator's Avatar
Wow. Thanks guys, love the help I always get in this thread. I think I'm going to rethread the bleeder valve. Looks almost like it belongs in there also as often as I seem to have to pull the radiator on this thing it's one less thing to fight with.
Old Aug 14, 2019 | 11:35 AM
killerpenguin21's Avatar
you want temp at the head as thats the damaging temp, thats the key.
crxsir07
Nov 12, 2006 04:05 PM
qwikz
Mar 2, 2006 07:26 PM
