1997 honda civic ex idle issue
Old Aug 10, 2019 | 08:56 PM
Francisco Rivas's Avatar
Default 1997 honda civic ex idle issue
I have an issue with an idle on my car I have changed idle air control valve map sensor throttle sensor new throttle body and check for leaks everything good but the idle just keeps going up and down
Old Aug 11, 2019 | 04:54 AM
muellersfan's Avatar
Default Re: 1997 honda civic ex idle issue
Did you bleed the cooling system?
Old Aug 11, 2019 | 08:10 AM
99stockcivic's Avatar
Trying to think past what you have replaced: Have you checked to make sure all pulleys are moving smoothly? For example, AC or alternator or idler pulley could be sticking or worn causing some tugging on it, which would causing an idle situation. Otherwise, I would continue on the maintenance by swapping in new plugs, wires, and distributor cap, as the whole bit there could be worn and not sparking cleaning, causing an idle issue.
Old Aug 11, 2019 | 09:59 AM
GamerOnHorizon's Avatar
I'm having the same issue.
Old Aug 11, 2019 | 08:07 PM
John Puckett's Avatar
With the idle constantly going up and down it sounds like you have a small vaccum leak, check your hoses and vaccum lines with the car running. Take some starting fluid and spary it around hoses if the rpm jumps up you've found your leak.
Old Aug 12, 2019 | 05:12 AM
mk378's Avatar
If it is a manual EX with a 2-wire IACV, unplug the IACV and confirm that the idle drops to lower than normal.
If it keeps going too fast there is an air leak.
If it does drop check the coolant temperature sensor, which as someone else said of course depends on the cooling system being full.
elli
Jun 1, 2010 01:22 PM
prjctwhteg
Nov 16, 2009 10:56 AM
Angelena
Oct 30, 2008 02:52 PM
5thGeneration
Jan 3, 2008 01:49 PM
