1992 Honda Accord LX vibrates at reverse gear and neutral gear
When engaged in either reverse gear or neutral gear, the engine vibrates. The neutral gear vibrates stronger than the reverse gear. Vibrations happen when the car is stationary or when on brake.
The other gears (P, D, D1, and D2) are normal and do not vibrate.
Could it be the front engine mounting bolt. Some say its the rear engine mounting bolt. Some say its the transmission mounting bolt.
Can anyone help figure out what is wrong.
