1998 civic d16y7 wont start
Old Aug 10, 2019 | 07:17 AM
greg hougland's Avatar
Default 1998 civic d16y7 wont start
My car is completely stock. Hes a little back story. It broke a timing belt a little while ago and bent a valve. So I pull a d16y7 head at a salvage yard and installed it when I replaced the timing belt. It would start and run but start up was a little rough so I replaced all the ignition components. Spark plugs, wires and distributor. Still rough so I took a look at timing and the crankshaft was off by a couple teeth so I moved it back and replaced the crankshaft position sensor while I was there and re installed everything. It fired up perfect and ran great on a test drive. I then parked it around 15 or so minutes later went to restart it and it wont start. It cranks but wont fire up. So I pulled it apart and everything on the timing side looks fine. Any idea what could be going on now? Thanks for whatever help you can
Old Aug 10, 2019 | 10:48 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 1998 civic d16y7 wont start
Loose or corroded engine harness ground... check all engine grounds in general. Bad ignition coil.
Old Aug 10, 2019 | 12:01 PM
muellersfan's Avatar
Also check for spark and listen for whether the fuel pump primes.
yo bj
Feb 2, 2011 05:54 PM
f22kid
Jul 17, 2009 09:47 AM
Tr0LL
Sep 24, 2008 04:40 AM
pbizzlegsr
Jul 7, 2004 10:23 PM
hondaeg8
16
May 6, 2004 01:40 PM
