Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Honda Civic gx window issue
Old Aug 8, 2019 | 05:17 AM
Chris Valkoe's Avatar
Default 2001 Honda Civic gx window issue
My 2001 Honda Civic gx passenger rear window will roll down not up only when using the rear switch not the master. I took apart both the drivers door and passenger door and tested it with the tester I got from autozone. It lights up the tester when I push down and up on both of the doors and I've even changed the motor/regulator. I'm not mechanically inclined at all what so ever so any insight or ideas are greatly appreciated
Old Aug 9, 2019 | 08:59 AM
NDNV's Avatar
Default Re: 2001 Honda Civic gx window issue
Check the driver's door wire harness for a broken wire. The harness in behind the rubber conduit between the 2 door hinges at the driver's front door. I have repaired 2 wires for non-functioning rear windows. The driver's door gets the most open/closing cycles that it eventually breaks the wires.
Hondaelementaz
Honda CR-V & Element
May 26, 2018 01:58 AM
Cracka63
Honda Civic (2006 - 2015)
Mar 28, 2018 06:15 AM
wcummins1313
Aug 26, 2017 08:35 PM
ahaihana
Aug 22, 2012 06:01 AM
ssssmashing
Jun 25, 2010 10:47 AM
