Accord engine swap
Old Aug 7, 2019 | 06:49 PM
kenwood customs's Avatar
Default Accord engine swap
Swapped engines 97accord with 92accord 2.2l no crank sensor. What to do?
Old Aug 9, 2019 | 12:07 PM
GhostAccord's Avatar
Default Re: Accord engine swap
You have 2 choices, convert your 97 (OBD2) wiring harness to match your 92 (OBD1) engine or convert the 92 engine with the OBD2gear..... the info is all over the internet for swaps like this......just saying
If it is already installed it's a bit of a PITA, but swap the 97 (OBD2) oil pump housing, TDC and CKP sensors, timing gear, balance shaft gear onto your 92 engine. Other choice is wiring the OBD2 TDC and CKP wiring harness to hook up to the TDC & CKP sensors in the OBD1 distributor.
Old Aug 13, 2019 | 08:23 AM
Default accord engine swap
i read that i can jumper 4 wires at the ecm to make vehicle think it has crank sensor hooked up. anyone heard of this? need help plz.
v4lu3s
Mar 28, 2012 06:20 PM
accordcvcc78
Classic Hondas
May 16, 2010 10:25 PM
cranberryman
Feb 9, 2007 07:00 AM
