ITR rear shock mount bolt
Hi there,
I was wondering for ITR’s for the shock mount bolt it DOESN’T have the lines on them correct and its a flat end, not the pointy ones like the GSR or LS?
Also, its a bit short and cost really dirt cheap??? If you have one off the car may you take a picture of the bolt! Please and thanks!
Correct me if I'm wrong but, The rear lower arm uses 2 different bolt lengths/numbers.
90173-SR3-003
90173-ST7-Z01
Which according to the parts diagram look like they carry over between base/gsr/R
The "slotted" ones like you pictured are the trailing arm/subframe bolts.
90173-SR3-003
90173-ST7-Z01
Ok did some research and digging
3 bolts for LCA
(1) LCA to subframe different from ITR and non ITR due to the difference in subframe
(2) LCA to Shock absorber different from ITR (shorter and smooth all around ) and non ITR (longer with indents see pic above)
(3) LCA to RTA same with ITR and non ITR
3 bolts for LCA
tree fingers
Jul 27, 2008 08:13 PM
Mr.Meowsome
Dec 1, 2006 11:27 AM
