Having strange overheat issues
Hey guys, just got my d16y8 swapped with a less mileage motor. After getting it back... Couple days later its overheating and I have a weird noise from what sounds to be the waterpump. Anyway that could be unrelated. But my car ONLY overheats when a/c temp **** is on cold and driving. At idle it will not overheat at all. All new belts, thermostat, hoses, radiator, fan switch, and ect sensor. Whats my next step. I've also flushed the system multiple times.
Details on bleeding? I jack the front end, remove cap, install bleeder funnel add fluid, start engine and rev engine constant around 2500 rpm until the radiator fan kicks on (yes it kicks on, but not until the temp is at like 190-200F, seems late to me with a 170f thermostat) then just let it go until air is gone.
The heater hose valve also must be wide open during the entire bleed procedure.
I would check temps on the radiator with an infrared thermometer. You can also check temps by touching the upper and lower radiator hoses with your hands. Upper should be warm, not boiling hot. The lower hose should be much cooler, not cold.
Do you have boiling water in the overflow tank?
Did you change the radiator cap?
Ok so took a infrared thermometer to the car, at idle it will not overheat, but top radiator hose is reading 160-180, bottom radiator hose is about the same but started out lower by about 20 degrees, thermostat housing reads approximately 160-170, top of radiator was reading 130-170 across the top, while my scanner is reading 180-209, new developments though.... Threw a p0505 code, which I replaced the iacv when i did the swap, idle is super low when a/c kicks on, then comes up to about 800, when i turn a/c off it kicks up to about 1200 rpm... So im not sure if this is all coincidence or if its all connected somehow. I know the iacv has coolant lines so i guess it would make sense, except its new and i bleed the **** out of the system after the motor swap.
Wtf. So it passes the block test, doesnt overheat with the heat on but it does ONLY with the a/c on. Im ****** so confused. If the head was cracked wouldn't it overheat ALL the time?
I think you have a bad fan switch. It should come on and run continously if it cannot get the temp down to 195° and when the fan is on is the temp still rising?
Maybe you have a inaccurate ect. If you can replace it as you are only relying on scan tool which is getting input from ect. Secondly if there is no boiling in overflow tank then you are not overheating assuming that the overflow tank is properly connected and radiator cap is working good.
