Help!!!! 2001 Honda Accord
Old Jul 31, 2019 | 08:11 PM
saco0242's Avatar
Default Help!!!! 2001 Honda Accord
So I have 2001 Honda Accord 2.3l 4cylinder it had a f23a4 with is the ulev vtec and I was burning oil so I swapped it with a F23A1 and when I finished swaping it I forgot to put coolant in and took It for a drive i heated up and i stopped and put coolant and then I got a check engine for a knock sensor so I changed that and cleared the code with a ob2 scanner and now when ever the ob2 scanner isn’t in it struggles to start and sometimes wants to turn off while driving
Old Aug 2, 2019 | 11:05 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Help!!!! 2001 Honda Accord
This is a ground issue.
With the scanner plugged int it provides a ground path through the scanner for the PCM. IIRC there are two grounds on the OBDII port one is a chassis ground the other is the PCM ground, which the scanner combines and completes the ground circuit for your. I *think* the grounds are pin # 4 and #5(VERIFY!!!), so if you run a jumper to those two it may temporarily solve the issue until you can fix it correctly. There is a reason why the grounds are normally divorced.
Recheck your engine harness main body ground, ground bonding jumpers and main battery grounds to the engine and the body.
Old Aug 8, 2019 | 11:17 AM
saco0242's Avatar
Thank you I had a ground cable lose
JC'S car
Jan 15, 2016 07:01 PM
samontherun
Jun 18, 2012 06:10 AM
nedoh
Mar 11, 2011 02:30 PM
