Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
08 TSX HELP!!!! electric power mr2 spyder pump and breaking racks
Old Jul 31, 2019 | 10:30 AM
boostedcl9's Avatar
Default 08 TSX HELP!!!! electric power mr2 spyder pump and breaking racks
i followed all the diy on the wiring for the electric power steering pump. found on the internett forums from k20.org org and hondatech, as well as other forums. for some reason this pump blows out my rack in the same place both times. i have even purchased another oem rack and still the same issue happens. the pump blows out the connector that goes into the rack on the right side where the part number stamp is on a 08 tsx 6speed
Old Aug 5, 2019 | 03:47 PM
boostedcl9's Avatar
Default Re: 08 TSX HELP!!!! electric power mr2 spyder pump and breaking racks
B
Old Aug 5, 2019 | 07:18 PM
Ryanthegreat1's Avatar
Pressure regulator on the pump stuck?
Old Aug 6, 2019 | 06:17 AM
boostedcl9's Avatar
it very well might be how do i check that? i also bought a new pump. from toyota so i hope its just a unlucky bad pump. is there a way i can confirm this? what is the voltage of the speed sensor range the pump runs on i cant seem to find the info
Old Aug 19, 2019 | 12:55 PM
boostedcl9's Avatar
UPDATE: I HAVE REPLACE THE pump with a new pump, and a new rack and it still leaks in the exact same spot!! any help would be appreciated!!
Old Aug 19, 2019 | 02:27 PM
Pictures?
Old Aug 19, 2019 | 03:06 PM
boostedcl9's Avatar
that rectangle thing, and the rack its pures fluid!! where the S E C IS!
Old Aug 19, 2019 | 05:33 PM
Is that where you are sending the output from the pump?
Old Aug 19, 2019 | 06:14 PM
boostedcl9's Avatar
that where the even pressure valves goes to the right of the rack
moh.rwashdeh@ya
Apr 12, 2018 04:37 PM
Raiderz8418
Jan 26, 2012 01:03 PM
Dekorum
Mar 20, 2011 02:32 PM
