Honda CR-V & Element 2WD & 4WD Element & CR-V
Crankshaft and bearing size
Old Jul 31, 2019 | 07:29 AM
DieselBlooded's Avatar
Default Crankshaft and bearing size
So I had to rebuild my crv motor and was wondering if the crankshaft and bearings were all the same size in a b20z2 motor and in a b20b4 motor. Due to lack of funds i have to try to piece together a working motor out of two different ones.
Old Jul 31, 2019 | 08:29 AM
Ryanthegreat1's Avatar
Default Re: Crankshaft and bearing size
Ill advised but check the block and crank for bearing size stampings. Should be A-D on the oil pan rail and 1-4 on the crank. Same for rod bearings, A-D on the crank and 1-4 on the rods. There is a matrix for size. Bearings are colored by size with a paint mark on the edge. That paint is probably long gone or discolored by now.
Old Aug 13, 2019 | 07:30 AM
starchland's Avatar
Download or get a copy of the factory service manual. It will mull answerall your questions regarding a rebuild
Coolero
Honda Civic (2001 - 2005)
Jun 10, 2008 12:28 PM
itralex
Sep 9, 2004 11:48 AM
