97 GS-R - fix or move on?
Old Jul 28, 2019 | 12:34 AM
jcewin42's Avatar
Default 97 GS-R - fix or move on?
I have a 97 GS-R with 230k that's my daily driver. It has a bad input shaft bearing. I don't know if I should replace the transmission or buy a different car. What would y'all do?
Old Jul 28, 2019 | 12:54 AM
tony_2018's Avatar
Fish Twig
Default Re: 97 GS-R - fix or move on?
Price of a new car?
Price of a used transmission?
Price of a transmission shop rebuild?
Old Jul 28, 2019 | 08:50 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Buy a new bearing.
Old Jul 28, 2019 | 11:47 AM
jcewin42's Avatar
Originally Posted by Caoboy
Buy a new bearing.
I would do this, but I don't have the tools or space to replace it myself. I could have a shop do it, but from what I've read, it would be more cost-efficient to have my transmission replaced than rebuilt.
Old Jul 28, 2019 | 11:56 AM
jcewin42's Avatar
Originally Posted by tony_2018
Price of a new car?
I have $1500 to work with. More if I sold or parted out my car.
I should be able to find a LS transmission for under $500 (https://hondaswap.com/threads/b-seri...n-guide.29099/), but I don't see any in marketplace or on craigslist right now.
Old Jul 28, 2019 | 12:01 PM
tony_2018's Avatar
Fish Twig
so your only option is
- quote on rebuild
- new clutch
- quote on resurface flywheel
- is it worth it to rebuild, are there any other issues with the car that can cost me more down the road?
Old Jul 28, 2019 | 12:06 PM
jcewin42's Avatar
- quote on rebuild
- new clutch
Why clutch and flywheel? Preventative maintenance?
No other issues at the moment, but it has 230k...
Old Jul 28, 2019 | 02:20 PM
tony_2018's Avatar
Fish Twig
why?
when was the last time it was replaced?
Old Jul 28, 2019 | 04:08 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
If you have the tools to replace the transmission you have the tools to replace the bearing.
Old Jul 28, 2019 | 06:22 PM
wunfstgsr's Avatar
Loved
Community Favorite
Just have a shop replace it shouldn't be much, buy the bearing from Honda and give it to them and all they should charge is labor maybe $160 to $240 or like 3 hr labor charge, some shops are $100 some are $80 per hr ect.
Old Jul 28, 2019 | 06:28 PM
turbociv910's Avatar
im selling a em1 b16 with ls 5th and a wavetrac lsd if you need a transmission
Old Jul 29, 2019 | 03:20 AM
89brokendownEF's Avatar
The bearing is like 20 bucks and just snaps into place
Old Jul 29, 2019 | 03:47 PM
thewrai6th's Avatar
I was not able to do this without a press. I mean, I did it via mallet/DIY style, but the new input shaft bearing only lasted 50 miles. There were shards of bearing all through the transmission that had to be flushed out.
? ISB is pressed in. Certainly doesn't snap in. OP is not referring to the clutch throwout bearing.
As Tony pointed out, if it's a solid chassis and you like the car, just fix it or get a new (used) transmission. Any other used car will have it's own gremlins, so that's a game of chance.
Old Jul 29, 2019 | 04:37 PM
It may not snap in but I've replaced em before on the ef si transmission they press into place with little effort not something you need a press for.. so easy a caveman could do it lol
Old Jul 30, 2019 | 07:25 AM
tony_2018's Avatar
Fish Twig
build a square frame and use your hydraulic jack to press it in?
Old Jul 30, 2019 | 09:32 AM
maxwellmercer's Avatar
Put it in the freezer for a day or so, use a piece of wood or something flat to drive it right in. Works like butter!
Old Aug 3, 2019 | 07:03 AM
jcewin42's Avatar
I don't have the tools to do either.
jcewin42's Avatar
I'll look into this, thanks!
Old Aug 3, 2019 | 07:08 AM
jcewin42's Avatar
Thanks for letting me know! That sounds awesome, but I think it's out of my price range.
Old Aug 3, 2019 | 07:10 AM
jcewin42's Avatar
Thanks for the input!
Old Aug 3, 2019 | 08:27 AM
MotorMouth93's Avatar
10 Year Member
What are the symptoms OP? If it’s just a bit of a whining noise you’re probably safe to ignore it until you have the resources to fix it. My brother drove his Civic with a whiney ISB for years while he was in college.
Old Aug 3, 2019 | 03:21 PM
wunfstgsr's Avatar
Loved
Community Favorite
Sounds like a job for...,
Old Aug 3, 2019 | 04:08 PM
jcewin42's Avatar
It's a loud grinding noise. It gets louder and the car lurches when I take my foot of the gas in first gear. I'm not sure if it's related, but it also makes a loud whining and rattling noise at about 3700 rpm.
jcewin42's Avatar
Originally Posted by Chrisfrom1986
Where are you located?
Northern Virginia.
Old Aug 3, 2019 | 04:17 PM
Chrisfrom1986's Avatar
Honestly at this point replacing just the ISB will not be enough. There is likely damage to all the bearings and you would need to completely clean and flush all the oil ports in the main and counter shaft.
I did this to my b16 trans that the ISB failed completely on. The only special tools needed were the 32mm axle nut, snap ring pliers for case disassembly and a small 2 jaw puller to remove the damaged ISB from the case.
Cost for oem parts from even the cheapest dealer will be near $500 for all the bearings except the differential. I didn't replace mine because they were the sealed type.
