Rear Disk Brake Handbrake
I recently purchased an Integra and I've finally set off to start working on the car. The car has rear disk brakes with an auxiliary drum brake for the parking brake, I'm curious to know what kind of parking brake system these would be associated with because for whatever reason I'm struggling to figure it out lol.
I picked up the full Brake caliper kit from Amazon for 25 bucks with all the different adapters and rh and lh threaded compression tools. It was well worth the cost even 40 at HF if you work on brakes on your vehicles. I have a few brands of cars including German and the kit has the adapter for it versus the 200 dollar set. If you remove the Caliper remember to readjust the Hand Brake. Its easy Loosen the cable at handle pull up 1 notch and tighten till slight drag button up and pull full should be right on.
