Ruckus keeps draining power please help
So my ruckus keeps draining power every time i connect the battery after charging it goes from 12 volts to under 5 volts as soon as i connect it. Battery terminals looks fine fuses are good im so lost
Does it lose voltage when you hit the start button? If yes then your battery might be dead.
If it loses voltage just by connecting it then you could have a blown relay. There are 2 black ones and 1 blue one.
