Which timing belt for 99 LX
Old Jul 24, 2019 | 03:43 AM
coloradotrout's Avatar
Default Which timing belt for 99 LX
I see Gates and Contitech recommended, but which part number? There's a high performance Gates for $63 on rockauto, or other Gates or Contitech under $10
Old Jul 24, 2019 | 03:59 AM
Default Re: [FAQ] Your Guide to Buying Quality Aftermarket Maintenance Parts for your Civic
Whats the latest on timing belt? There is a Gates high performance for $63 on rockauto. Or will the sub $10 Gates or Contitech do?
Old Jul 24, 2019 | 04:08 AM
Default Re: Which timing belt for 99 LX
Or Aisin?
Old Jul 24, 2019 | 06:10 AM
tony_2018's Avatar
Fish Twig
whats wrong with oem?
Old Jul 24, 2019 | 09:29 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Gates, Contitech, Bando, Mitsuboshi. These are all reputable brands. No you don't need a $63 one.
Old Jul 24, 2019 | 09:32 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It costs more than $10.
Old Jul 25, 2019 | 02:26 AM
NVturbo's Avatar
O.G. triple O.G.
where would you find a new timing belt for under $10? That's what I wanna know.
Old Jul 25, 2019 | 07:03 AM
BauleyCivic's Avatar
Risky Business
Stick with the OEM timing belt. That's a part you don't want to cheap out on.
Old Jul 25, 2019 | 07:57 AM
tony_2018's Avatar
Fish Twig
At this point I'd just say get whatevers in your budget...
Old Jul 25, 2019 | 02:07 PM
Or should I got Honda OEM for the TB?
Old Jul 25, 2019 | 02:11 PM
I'm good with OEM, just like ordering online as the Honda dealer is 50 miles away!
Old Jul 25, 2019 | 03:17 PM
tony_2018's Avatar
Fish Twig
there are online oem parts dealers too...
Old Jul 25, 2019 | 04:36 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
You can but don't have to. Quite a few quality belts all of which deschlong mentioned.
I moved all relevant posts to here since you were just asking the exact same things in two different threads. Should keep it all in your thread here.
Old Jul 26, 2019 | 09:05 AM
Is this good?
https://www.amazon.com/Evergreen-TBK224MVCA2-96-00-Timing-Gasket/dp/B00N48BLO4/ref=sr_1_2?_encoding=UTF8&qid=1564158033&s=automotive&sr=1-2&vehicle=1999-59-752-113--1--5-5752-1441-1-1---4&vehicleName=1999+Honda+Civic https://www.amazon.com/Evergreen-TBK224MVCA2-96-00-Timing-Gasket/dp/B00N48BLO4/ref=sr_1_2?_encoding=UTF8&qid=1564158033&s=automotive&sr=1-2&vehicle=1999-59-752-113--1--5-5752-1441-1-1---4&vehicleName=1999+Honda+Civic
Aisin pump, Mitsuboshi belt, I may just reuse the tensioner,
I do then need 3 belts, so maybe the Bando set
https://www.amazon.com/Replacement-Quality-Serpentine-Belt-COMPLETE/dp/B06W521XYC/ref=sr_1_4?keywords=bando+belts+civic&qid=1564160783&s=automotive&sr=1-4 https://www.amazon.com/Replacement-Quality-Serpentine-Belt-COMPLETE/dp/B06W521XYC/ref=sr_1_4?keywords=bando+belts+civic&qid=1564160783&s=automotive&sr=1-4
Old Jul 26, 2019 | 11:52 AM
NVturbo's Avatar
O.G. triple O.G.
YES
YES
Old Jul 27, 2019 | 08:22 AM
I know I am over thinking this. What about this kit vs the two I posted earlier?
Amazon Amazon
Features & details
NPW water pump made in Japan 19200-P2A-A01
Bando drive belts 31110-P2A-004, Drive Belt Alternator 38920-P2A-013 Drive Belt Air Conditioner 38920-P3F-003, Drive Belt Power Steering Belt
NSK 14520-P2A-305 Timing Belt Tensioner made in Japan
Conti-tech timing belt 14400-P2F-A01, Timing Belt
Factory Honda Spring 14516-P2A-J00
$128
The other:
1 Mitsuboshi Timing Belt (104 teeth) (Mitsuboshi - OE Supplier for HONDA / SUBARU)
1 GMB Roller Tensioner Bearing ( bearing assembly)
1 Camshaft Seal (29 x 45 x 8)
1 Front Crankshaft Seal (31 x 46 x 8)
1 AISIN Water Pump with Gasket (AISIN - OE Supplier for TOYOTA / LEXUS)
1 Valve Cover Gasket
5 Grommets
4 Spark Plug Tube Seal
A separate bando belt kit
$118 total
mjb9369
Jan 19, 2017 07:53 PM
joeys
Honda CR-V & Element
Nov 3, 2013 10:57 AM
phat00civic
Jun 6, 2011 07:39 PM
feiyi
Jun 13, 2007 09:04 PM
b18LS
May 2, 2007 11:11 AM
