Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
Cant get my led turn signals to work
Old Jul 23, 2019 | 12:16 PM
rucker's Avatar
Default Cant get my led turn signals to work
Hello,
New member and hoping someone here can help me with a problem I am having. I bought a used ruckus some time ago. Previous owner has installed a LED taillight with integrated turn signals which works as they should. The front turn signals are the original ones but when i replaced them with LED's, front and rear did not flash, just a static light.
As seen on the picture, the flasher has been replaced to accommodate the rear LED so not sure why they don't work when I install the front LED's.
Tips on how to resolve this would be very appreciated.
Flasher
Br
Old Aug 21, 2019 | 08:11 AM
rchid's Avatar
Default Re: Cant get my led turn signals to work
did you ever get this working? I am having the same issues as you
Old Sep 8, 2019 | 10:42 AM
sTol2m's Avatar
You guys need a led flasher relay like the 'ELFR-1'. It should solve your problems.
The relays at Autozone/Pepboys won't work when using 4 led signals. They only work with 2 led signals.
Old Sep 11, 2019 | 06:36 AM
rchid's Avatar
I have the ELFR-1 relay that I bought from mnntbx. I have another issue which you addressed in my thread, so I shouldn't speak on my turn signals not working at the moment until I get my ruckus started. Hopefully Once it starts it will all be fixed. OP here is a link to the flasher relay I bought.
https://mnnthbx.com/product/electron...om-ruckus-met/
D7_62
Jun 20, 2010 05:53 PM
joblow
Nov 14, 2002 08:49 PM
