1994 civic ex sedan - orange plugs disconnected
Old Jul 22, 2019 | 11:07 AM
Eh9newb's Avatar
Default 1994 civic ex sedan - orange plugs disconnected
Hey all, just picked this up for my daily and new to this was just looking in engine bay and saw these disconnected. Any one know what these are for?
Old Jul 22, 2019 | 05:09 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: 1994 civic ex sedan
To be honest, I do not believe I've ever seen orange OEM plugs on a 5th gen civic.
Old Jul 22, 2019 | 05:53 PM
Bheriya's Avatar
Those are all ABS Plugs. I believe some came unplugged from factory but you should still try to see if they have a match.
Old Jul 22, 2019 | 06:46 PM
muellersfan's Avatar
OP should look for ABS modular unit in engine bay.
Old Jul 22, 2019 | 10:11 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Those two plugs should connect together. They are the main power wires for the ABS accumulator/control system. ABS was an option on the EX Coupe and Sedan as well as the Si hatchback. It is likely unplugged because the previous owner had problems with it... they are NOT unplugged from the factory.
Old Jul 23, 2019 | 10:28 AM
Eh9newb's Avatar
thanks all! Do i need to connect them or should it be fine without it? I just use it as my daily just work and home
Old Jul 23, 2019 | 06:35 PM
cp_auto12's Avatar
You don't need it attached. It just prevents brakes locking when sliding on ice. Alot of abs systems in older hondas are usually on the verge of not working anyway. Might be a reason why they're not connected
Old Jul 23, 2019 | 07:10 PM
I disagree. OP -- it's in your best interest with regard to safety to get the system working, especially if the solution is simple and inexpensive.
Old Jul 23, 2019 | 07:56 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
I agree with mullersfan but if you're a newbie then diagnosing and fixing ABS problems can be a deep dive right off the hop. Your conventional brakes will function normally, so there is no safety issue from that standpoint.
But, do check the problem code to see how difficult it is to repair. Could be fairly straightforward. Could be quite tricky (like a Code 1 error). The ABS computer hiding in the trunk may also need reconnecting if the PO disconnected it.
Old Jul 23, 2019 | 08:20 PM
cp_auto12's Avatar
Yes if its qn easy fix do it obviously but lots of older cars don't have abs and they're fine. If you live somewhere where it rains alot or snows then definatly look into it.
Old Jul 23, 2019 | 08:59 PM
Default Re: 1994 civic ex sedan - orange plugs disconnected
ABS improves braking safety under ALL conditions. If you can get the ABS system working properly, then do it. It just makes sense.
Old Jul 23, 2019 | 09:03 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Yes, this ^^^^^^^^^^ !!!
Old Jul 30, 2019 | 11:08 AM
deschlong's Avatar
Loved
Community Favorite
Updates, OP?
Old Jul 30, 2019 | 03:05 PM
chrysler kid's Avatar
Has anyone ever put abs on a 6th gen coupe? I know only automatic 99-00 ex sedans had them
Old Jul 30, 2019 | 04:00 PM
deschlong's Avatar
Loved
Community Favorite
CDM SiR had ABS
KiDSoL
Jan 19, 2004 09:21 PM
Bnjmn
Oct 1, 2003 04:19 PM
GetawayInMoscow
10
Mar 28, 2003 01:49 PM
Spade
Aug 9, 2002 03:37 PM
