1995 engine on 1997 accord no spark
Hello I just finish my swap from a 1995 accord engine f22b2 OBD1 into a 1997 accord same engine but OBD2 every plug fit perfect, there's only one that I could not connect because there's is no plug to connect it to , it is the CK sensor I believe, but the 95 engine does not have one, I also change the distributor, I was reading about it and it looks like that's why there is no spark, can somebody help me with that, I appreciate any help. Thanks !!!!!
Your two options are to either;
Install a '96/97 oil pump and the two pickup sensors like factory.
or
Install the '95 distributor and rewire the connector so the two sensors that are in the distributor take place of the missing oil pump sensors.
or
Hello again I just finish installing the oil pump, but still no spark, you mention something about rewiring can you point me on that direction, like what cable connect to what other cable please, thanks a lot
If you installed the OBD2 (96-97) oil pump housing, you need to also install the CKP and TDC sensors that were on it. This way you can hook them up to the two connectors that you couldn't hook up before. In order for this to work you also need to use the 96 timing gear and crank pulley. These gears have the timing tabs that the VR sensors use to send the timing signals to the ECU. The 94-95 OBD1 gear and pulley do not have these tabs and will not work with an OBD2 setup.
There is no codes or nothing, but I'm going to start working on swapping the gears and I will keep you posted, thanks again
Stang69
Jun 29, 2019 06:05 AM
JRad
May 14, 2017 09:12 AM
CaliforniaDad
May 4, 2013 07:30 AM
accord96lx
May 25, 2012 09:39 PM
