Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Honda Civic Timing Belt?
Old Jul 21, 2019 | 07:14 AM
sunnysioux's Avatar
Default 2001 Honda Civic Timing Belt?
Yesterday I was driving my car in town, 2001 Honda Civic EX, going about 25 mph. Heard a clunk, almost sounded like I had hit a small rock, then battery light and oil light came on. I tried to accelerate, car didn't respond. Lost all power, coasted and was able to make it to a side road safely. The car will turn over but won't start. Lights turned on. Battery is okay. Checked the oil, almost empty. This is obviously a problem. Previously over 6 months ago, I was losing a bit of oil and we replaced the valve cover gasket. That seemed to have fixed the issue. I am not due for another several hundred miles for servicing. No, I hadn't recently checked the oil and I know better not to go for so long without checking it and it could have been easily preventable. A+ for being an idiot!
No knocking or squealing was heard. No check engine/oil/battery lights came over before incident. Temperature gauge was normal. No Smoke. Nothing. Was running just fine, no signs that there was anything wrong.
I had taken the car the day before, over 200 miles and had it up to 70 mph. Was running like normal.
I could have two separate issues here. Oil issue and the issue of why it is not starting. The timing belt seems very likely.
Any suggestions on what to look at, test. etc would be very helpful.
Thank you.
Old Jul 21, 2019 | 07:24 AM
hondaslave1342's Avatar
Default Re: 2001 Honda Civic Timing Belt?
When trying to start the vehicle, does it turn over normally..or spins freely..definitely check to see if TB is intact..may have damaged engine by trying to start..remove valve cover and check belt
Old Jul 22, 2019 | 12:24 PM
civichxtreme2's Avatar
How many miles on this sled?
Weez1
Honda CR-V & Element
14
Jun 17, 2013 09:32 AM
01hondaEX1.7_ky
May 1, 2013 07:37 AM
JERRYNG
Nov 23, 2012 07:44 AM
andoxviii
Feb 29, 2012 06:13 AM
p3anutboi
18
Sep 19, 2011 02:29 AM
