Honda CR-V & Element 2WD & 4WD Element & CR-V
Solenoid buzz form both back doors
Old Jul 21, 2019 | 05:46 AM
woodman2k's Avatar
Default Solenoid buzz form both back doors
I'm getting a wicked buzz from the solenoids that lock the rear doors when first starting off. I am wondering if somebody here can tell me what the actual components that I need to order are called
I appologize if thia question has already been asked a thousand times but I need to order the parts and felt asking would be the quickest way.
Thanx,
Greg
Old Jul 22, 2019 | 09:49 AM
canister's Avatar
5 Year Member
Default Re: Solenoid buzz form both back doors
Buzz means a short circuit more often then not. Whip out a multimeter and look for the short.
Old Jul 22, 2019 | 05:50 PM
woodman2k's Avatar
I work in the electrical field so I have eliminated all the possibilities, You tube says they are a consistent problem in the CRV. So I've resigned myself to replacing the assembly but need to know the official name so I can find them and order them.
Thanx for the suggestion
Old Jul 22, 2019 | 07:57 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
You never gave information regarding the model year. On older model Hondas, the buzzing may be due to one or both rubber stops in the door lock actuator that is torn. Although this other thread was specific to older Accords, it has an explanation (with images) of what may be causing the buzzing or cycling, and how it can be possibly repaired without replacement with a new actuator. However, you can also just replace with new.
https://www.hondaaccordforum.com/for...cycling-48713/
Denis1985
Apr 22, 2009 07:23 AM
shocker911
Mar 16, 2009 07:31 PM
1990hondacrxhf
Apr 29, 2007 07:45 PM
citrus3000psi
Feb 26, 2006 05:43 PM
