Failed smog due to high HC at 15mph.
Old Jul 20, 2019 | 01:58 PM
Robert Martinez's Avatar
Default Failed smog due to high HC at 15mph.
I cant figure out why my 95 Honda Civic Dx failed only the HC (PPM) emission test. Max is 68 and i got 83. Any clues?
Did tune up and oil change.
Cats passed. Everything passed except for the 15mph HC (PPM).
Old Jul 20, 2019 | 04:35 PM
muellersfan's Avatar
Default Re: Failed smog due to high HC at 15mph.
When was the last ignition system tune up?
The O2 value should always be zero. The 0.1 O2 value at 15 mph suggests a possible exhaust leak that makes the engine run rich.
NO levels are also a bit high, suggesting the cat may also be failing.
Old Jul 20, 2019 | 04:41 PM
mk378's Avatar
"Catalytic converter: Pass" only means that they looked under the car and saw it hadn't been removed.
Old Jul 20, 2019 | 04:45 PM
just did a tune up 2 days ago. And oil change yesterday. My Cats said they passed, but even with it saying they passed could it cause the 15mph test to fail? So my o2 being 0.1 can cause it to run to rich to fail it as well because its only says that at the 15mph not the 25mph. Thats why im confused.
Old Jul 20, 2019 | 04:55 PM
Check for an exhaust leak near or around the O2 sensor. For example, it's not uncommon for the header to develop a crack near the O2 sensor bung.
The somewhat high levels of both HC and NO suggest that the running rich condition is killing the cat. Fix before the cat is dead. Otherwise, the fix becomes more expensive.
Old Jul 20, 2019 | 04:58 PM
okay ill check it out.. Thank you. Usually when i fail something, something else fails as well, so i have an idea of what its from.
Check for an exhaust leak near or around the O2 sensor. It's not uncommon for the header to develop a crack near the O2 sensor bung.
The somewhat high HC and NO levels suggest that the running rich condition is killing the cat. Fix before the cat is dead. Otherwise, the fix becomes more expensive.
zerovandez
Feb 2, 2013 07:28 PM
cantbetouched24
35
Oct 6, 2010 09:01 PM
My_EFsedan
Nov 18, 2009 06:54 AM
Ruben19
Jul 7, 2009 01:18 PM
Herbie
Nov 6, 2006 07:45 AM
