Gsr Crv
I haven't done the swap myself, but since the GSR has VTEC and the CR-V doesn't I'd bet you're better off just using the entire GSR harness and PCM. You'll probably want to search on here to find someone who's done the swap already, or at least done a GSR head swap (which is a pretty common mod).
Thanks for the reply, I’ll definitely have to do more more research, I was at work yesterday to reseal and replace all parts on the Gsr while it’s out, I had disconnected the engine harness on both sides located by the strut towers in the engine bay and pulled it with the engine, so I had it side by side with crv to find out my does not have the engine sub harness connections like Integras/civics I just totally assumed it would, you know what the say when you assume, and that’s how I felt and laughed. Anyway thanks for the advice I’m definitely trying to get the hang of navigating through this Honda-tech website.
