Suspension & Brakes Theory, alignment, spring rates....
Engine Vacuum & Brake Booster
Old Jul 19, 2019 | 05:57 PM
Accordian47's Avatar
10 Year Member
Default Engine Vacuum & Brake Booster
Does engine vacuum reach a certain level or become a "full vacuum" to the point where there really isnt any such thing as the need for more? I don't know enough about the physics or measurement of vacuum but I thought to increase the vacuum the booster sees to improve braking but I am thinking that the vacuum in the booster basically gets to a full vacuum and thats it, its up to how large the diaphragm's surface area is to change braking pressure. Am I right in this or is there room to increase vacuum seen by the booster with an auxiliary pump?
Old Jul 24, 2019 | 06:36 PM
10 Year Member
Default Re: Engine Vacuum & Brake Booster
Anyone?
Old Jul 25, 2019 | 03:43 AM
10 Year Member
From what I have gathered, engine vacuum should be anywhere from 8-22inHg. So the most vacuum the booster ever sees is about 18-22inHg, higher at idle than cruising but even higher when on decel at higher rpms with the throttle closed. A "full" vacuum would be a vacuum as strong as atmospheric pressure (atmospheric pressure is what acts on the pedal side of the booster against the vacuum assisted side). Atmospheric pressure is approx. 14.7psi @ sea level or 29.9inHg. No engine is going to make that much vacuum at least at idle. 22inHg equals about 10.8psi. So I guess its worth running an electric vacuum pump designed to create a 20-22inHg vacuum at all times to ensure the booster is working as best it can. Let me know your thoughts.
Pman92
Sep 19, 2007 04:59 PM
Trickturn
Oct 10, 2006 08:13 AM
AcidGord
Dec 24, 2003 10:38 AM
98R-1144
Mar 21, 2003 04:28 AM
