Accord Brake Line???
Old Nov 14, 2002 | 03:18 PM
D21X's Avatar
Default Accord Brake Line???
how's it going guys!!! i have a 91 accord lx 4d akebono calipers and rear drums. i have 130k and i'm still on stock rotors, calipers, line, fluid(yes never changed). during spring brake i plan to replace rotors, caliper, line and fluid. so far i have brembo blanks, rebuilt calipers, and i'm looking for brake lines. i don't need stainless steel goodridge because i'm not hardcore racer or anything. anyone know where i can get some? i've looked at some of the parts stores online but i'm not sure if they're any good and if the pricing is right. oh and i'm going with Hawk HPS pads. thanks!!!
[Modified by D21X, 4:18 PM 11/14/2002]
Old Nov 14, 2002 | 04:08 PM
jweller's Avatar
Default Re: Accord Brake Line??? (D21X)
well if you don't want to get SS lines then just go OEM. either your local dealer or http://www.hondaautomotiveparts.com
130k on brake fluid, uuuhhhmmm yeah, your only like 85k - 90k overdue
Old Nov 14, 2002 | 04:11 PM
RotaryBzzz's Avatar
Default Re: Accord Brake Line??? (jweller)
yeah....be real careful when you bleed that master cylinder in that kind of condition. Don't use a pressure bleeder...i gar-run-tee you'll blow the cylinder out if you do...
Old Nov 14, 2002 | 04:34 PM
D21X's Avatar
uuummmm...............which parts do i need??? i see too many numbers and diagrams and have no clue what i all need. thanks!!!
Old Nov 14, 2002 | 06:21 PM
SOHCArchangel's Avatar
and have you tried
a) reviewing your post on what you plan to do, and the responses to your post
and
b) READING what you see, if you scroll down all the numbers and diagrams are broken out in order explaining what they are, and guess what?!?!?!?! it even tells you how much the parts are !, and get this if you click the magic shopping cart, you might just be able to order it right then and there !!!!!!!!!!!!!!!!!! yAy!
Old Nov 14, 2002 | 06:26 PM
Eskram's Avatar
Have you considered cross-drilled brake lines?
They increase air flow to your brake fluid which will disapate heat, and therefore lower brake pad and lugnut temperatures.
Kale Co. Auto has them on special for $50 each.
Check it out: http://www.kalecoauto.com/perf.htm
Edit: They're on special for $90 a pair.
[Modified by Eskram, 10:27 PM 11/14/2002]
Old Nov 14, 2002 | 06:30 PM
Drew M's Avatar
New User
*Shakes head*
Darwin must be on vacation this month . . .
Old Nov 14, 2002 | 07:30 PM
Nick M's Avatar
Default Re: Accord Brake Line??? (Drew M)
Old Nov 15, 2002 | 04:48 AM
Stew Pidasso's Avatar
Default Re: Accord Brake Line??? (Eskram)
This site kicks ***!! The prices are great too! If only they had a Helix Power Tower and a leaf blower turbo charger I could get all my performance accessories in one place.
Old Nov 15, 2002 | 09:32 AM
notoriousB's Avatar
Default Re: Accord Brake Line??? (Stew Pidasso)
what, no muffler bearings on that site?
Old Nov 15, 2002 | 09:45 AM
Gennady's Avatar
New User
Default Re: Accord Brake Line??? (notoriousB)
I have yet to find a reputable dealer of centrifical distribulators.
ndiehm
Aug 15, 2011 08:56 PM
streetsold6teeny8
Nov 18, 2009 05:24 PM
scotter031
Jan 30, 2008 06:48 PM
Rob Dizzle
Sep 25, 2001 06:14 PM
