handbrake light staying on
Old Jul 14, 2019 | 12:50 PM
Demigod2019's Avatar
Default handbrake light staying on
So i have recently changed the brake master cylinder and now the handbrake light is staying on,any ideas??
Thanks
Old Jul 21, 2019 | 05:50 AM
r_kage's Avatar
Default Re: handbrake light staying on
A fast google search revealed that this can happen if the brake fluid level is low.... so check double check that, and also curious, did you bench bleed the master cylinder?
Old Jul 23, 2019 | 10:18 AM
rs012881's Avatar
The other option you can check is to check your brake lights in the back. My brake lights stayed on for a while even after I put in brake fluid. Once I went to check my brake lights, I realized I had one that was burnt out. As soon as I replaced it, the light disappeared. Haven't seen it since then.
'Accord Ex'
Jan 23, 2007 07:18 PM
choua01
May 29, 2006 05:59 PM
white99accordEX
Dec 22, 2005 04:08 AM
speedaholic92
Jan 21, 2004 09:20 AM
01SilverGSR
Dec 29, 2002 11:59 AM
