Transmission & Drivetrain Gearboxes, Differentials, Clutches
Gears not engaging while Running
Old Jul 7, 2019 | 01:33 AM
Dylan Galdes's Avatar
Icon4 Gears not engaging while Running
So I have a 90s civic with a d13 gearbox connected to a d15b vtec, I changed gearbox and brand new clutch, the geabox is a cable box. When car is shut down all gears go into place when I switch on press the clutch no gears goes in. Reverse gear goes in then crunches but no other gears Go in like reverse does they just get stuck. I broke the cloutch cable and temporarly just to check if car goes into gear I jacked up the clutch pedal that the cable is connected to all the way up until its touching with the gearbox casing itself. Any idea what the problem might be?? clutch, pressure plate, and release bearing are all brand new Exedy
Old Jul 7, 2019 | 09:00 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Gears not engaging while Running
You are over-stroking the clutch moving the release arm that far.
Old Jul 7, 2019 | 10:11 PM
So the clutch fork should never be pulled all the way up? I will be buying a new clutch cable today and maybe try and put it in how do I know when the cable is setup to tight or is still loose while setting it, because the old one I believe I snapped it due to overtightening it, but still needed replacement soon it was patched all over.
Old Jul 7, 2019 | 11:50 PM
If I jack it all the way up then start putting it down slowly slowly while trying to put in gear, I shall find the engagement point Im guessing right?
Old Jul 8, 2019 | 10:26 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Yes, you should if everything else is correct and properly functioning.
