I hate to sell this but have no choice. I built the whole car so that why its hard to let go.
Clean title Wiseco turbo pistons K541M81AP Eagle rods Ebay turbo kit Skunk2 coil overs Jnc rims 205/45/16 tires Megan angle full exhaust New hid headlights drilled Rotors brakes Oem timing belt Oem Waterpump Oem Oilpump oil catch can AN10 Emusa waste gate SSQV BOV ACL racing bearings boost gauge 52mm A/R gauge 52mm new control arms Walboro fuel pump Non vtec chipped Ecu Competition 12lbs Flywheel Clutch eXpert stage 5 clutch VMS Racing distribution cap and wires NGK sprak plugs ARP Head bolts, pressure plate Flywheel bolts Moroso racing oil pan Hasports engine mounts 2row Racing radiator MLS head gasket rear control arms. ac installed I have other parts installed that I may have left out. cons: slight Coolant leak and oil leak Less than 500 miles on all parts
I also have a current video (7/6) of it driving
