Are/were there 83mm cast pistons?
Old Jul 4, 2019 | 09:31 PM
night's Avatar
Default Are/were there 83mm cast pistons?
Like the YCP or RS, I can't find anything :/
Old Jul 5, 2019 | 04:05 AM
TheShodan's Avatar
Moderator
Default Re: Are/were there 83mm cast pistons?
You won't. The idea never gained enough popularity with consumers. You have to sleeve the block anything over 82mm. The consumer in that situation isn't going to spend thousands to sleeve a block just to put in cast pistons.
84 mm was more common as it was based off of the B20 block. That's why options jumped from 82mm to 84mm.
Give it up.
Old Jul 5, 2019 | 07:51 AM
night's Avatar
My bore is 82.7, but thanks.
Don't wanna go straight to 84 with no room to rebore.
Old Jul 5, 2019 | 08:38 AM
Chrisfrom1986's Avatar
D series guys were using Toyota 1GGTE pistons before vitaras became popular, it's up to you to do the research needed to find out what 83mm piston will work for you.
Old Jul 6, 2019 | 04:54 PM
TheShodan's Avatar
Moderator
Can easily go to 84.5 to 84.6 before you have to replace the sleeve.
You're at the maximum safe bore on a stock sleeve with 82.7mm
Old Jul 8, 2019 | 06:57 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
If his bore is 82.7mm odds are it's not a standard b series engine and he's looking to find some honda pistons to fit a different engine with the same size wrist pin and compression height. Just a guess.
Old Jul 8, 2019 | 11:58 AM
night's Avatar
^ Yes. Iron block, stock 82.7. A series from '85 to '89 (and farther back in the E stuff). Same rods as LS except has smaller piston pin. Only a 12-valve, but not paying for custom pistons when we can get a cheap bump in compression from cast.
I may get a pic and measure sleeve thickness tonight and see what you guys think. I know this has already been done before, but I just can't quite feel comfortable about 84mm yet.
Old Jul 8, 2019 | 02:08 PM
TheShodan's Avatar
Moderator
That changes things completely. A-series Acura 1st gen Integra. No one used those in a cast, at least not in the states.
Old Jul 9, 2019 | 07:08 PM
night's Avatar
1gen teg is a dual cam D. But a one off oddity like the B20A
Old Jan 7, 2022 | 04:12 PM
Matt8314's Avatar
I know this is an old thread. But for those who may be looking for an 83mm cast piston, Honda DID make one. An 83mm cast piston can be found in the B21A from the 1990-1991 Prelude 2.1 SI. I am not sure how compatible this piston is with more modern B-series motors in terms of compression height and piston pin diameter. But unlike the A-series piston, the B21A piston has valve reliefs for four valves per cylinder.
enlque
Oct 30, 2010 01:05 PM
evade this honda
Jul 28, 2006 07:20 PM
camlob
Apr 22, 2006 01:42 PM
fastcivicboy
Mar 21, 2005 08:51 AM
Propulsion
Sep 28, 2003 12:21 PM
