3 sensors on back of b16a block are 1 knock, 2 oil temp,3 ...???
So oil pressure sender goes to the Gauge cluster right? It wasnt hooked up to anything when I pulled the motor so I was curious.
The three sensors on the back side of the block are: the knock sensor, the oil press sensor, and the thermoswitch. The Thermoswitch is not to be confused with the coolant temp sensor, or sender unit on the side of the cylinder head.
Answer your question?
to the ecu my brotha
joedr
Nov 9, 2008 12:11 PM
Playa_FL
Mar 21, 2007 06:47 PM
h22_crx
Jan 19, 2007 03:06 PM
