Transmission & Drivetrain Gearboxes, Differentials, Clutches
How-to: Tear Down and Rebuild 2002 Honda Odyssey Transmission
Old Jun 30, 2019 | 08:31 PM
eksine's Avatar
Default How-to: Tear Down and Rebuild 2002 Honda Odyssey Transmission
Hello, I will be showing you how to tear down and rebuild your automatic transmission (transaxle) on your Honda/ Acura. The NHTSA published several reports detailing the results of their findings on the automatic transmission failures for the TL 3.2L engine. I am talking about all of the Honda/ Acura transmission recalls of this era. The report states the causes of these transmission failures. If you look at the video description it links to my 2 articles about which parts are causing the transmission to fail and the solutions I found.
https://www.odyclub.com/threads/quic...ission.353519/
https://www.odyclub.com/threads/foun...roblem.352145/
This is a massive video series. It will get better as it progresses so if you are patient it will be worth it. Explains all you ever wanted to know about these transmissions.
Make sure you watch in the highest quality setting: 1080p. Although this is for a 2002 Odyssey, they use very similar designs for many vehicles. the slight differences would be, for example, the orientation for the step groove on the reverse selector ring. These were the ones on the recall list however many other transmissions were similar, so this guide applies to a huge list of vehicles not on the recall:
2002-04 Odyssey
2003–04 Pilot
2001–02 Acura MDX
2003–04 Accord V-6
2000–04 Acura 3.2 TL
2001–03 Acura 3.2 CL
Part 1:
Part 2:
Old Jun 30, 2019 | 08:32 PM
eksine's Avatar
Default Re: How-to: Tear Down and Rebuild 2002 Honda Odyssey Transmission
Part 3
Part 4
Part 5
Old Jun 30, 2019 | 08:33 PM
eksine's Avatar
Part 6
Part 7
Also part 13 will be one of the most important parts, it talks and shows the thrust washer for 3rd clutch for the 5 speed. for 4 speed auto transmissions you will need to grind out the thrust washer for 2nd clutch yourself. the links for the 2 articles I wrote explain it
Old Jun 30, 2019 | 08:34 PM
eksine's Avatar
Part 8
Part 9
Old Jun 30, 2019 | 08:36 PM
eksine's Avatar
Part 10
Part 11
Part 12
eksine's Avatar
Part 13 (an important part)
Part 14
Part 15
Old Jun 30, 2019 | 08:37 PM
eksine's Avatar
Part 16
Part 17
Part 18
eksine's Avatar
Part 19
Part 20
Part 21
Old Jun 30, 2019 | 08:38 PM
eksine's Avatar
Part 22
Part 23
Part 24
Old Jun 30, 2019 | 08:39 PM
eksine's Avatar
Part 25
Part 26
Part 27
eksine's Avatar
Part 28
Part 29 (This is the last part)
