1998 Accord 6 cylinder idles rough stalls and engine hot very .
Old Jun 29, 2019 | 04:44 PM
Stang69's Avatar
Default 1998 Accord 6 cylinder idles rough stalls and engine hot very .
Accord 6 cylinder idles rough stalls and engine gets very hot. All of a sudden I start the car and it wants to stall I step on the pedal to get a gas and it's barely running very rough. Heather idol about 5 minutes and the engine gets very hot where I can't even touch the radiator hose. Any suggestions. I replaced the spark plugs and spark plug wires new EGR valve cleaned throttle body.
Old Jun 29, 2019 | 06:03 PM
hondaslave1342's Avatar
Default Re: 1998 Accord 6 cylinder idles rough stalls and engine hot very .
Check engine light on?
Old Jun 29, 2019 | 06:13 PM
Stang69's Avatar
Yes, codes came up for a cylinders 1-3-4,6 . Change spark plugs and wires. Cleaned throttle body thoroughly and removed carbon buildup. Chuck manifold off and cleaned the ports that had carbon build-up.
Old Jun 29, 2019 | 06:54 PM
What codes..that would be helpful..
Old Jun 29, 2019 | 07:47 PM
Stang69's Avatar
P0300, p0301, p0303, p0304, p0306
Old Jun 29, 2019 | 08:25 PM
Multiple cylinder misfire..what is the condition of the spark plugs..wires..
Old Jun 30, 2019 | 04:20 AM
Stang69's Avatar
They were about 5 years old. I replaced them yesterday along with new spark plugs. I am going to recheck the spark plugs and gap. New distributor and rotor yesterday as well. Old distributor had some oil in it. I'm thinking pcv could be part of the issue,? The temperature gauge stays in the middle. It doesn't overheat, but the engine manifold and radiator hose seems very hot. Car has 197,000 on it and was garaged out of weather all theses years. I replaced the gas fill tube because of rust as well.
Old Jun 30, 2019 | 08:23 AM
Honda vehicles are very picky about ignition parts..use only Ngk or denso plugs..
Old Jun 30, 2019 | 08:28 AM
Stang69's Avatar
ngk installed. i want to make sure of the firing sequence on the distributor. i'm thinking some wires are put on wrong. i marked them but the markings came off. while handling them. distributor is facing driverside fender with mounting screws 2 and 7 o'clock.
Old Jun 30, 2019 | 11:14 AM
Old Jun 30, 2019 | 11:50 AM
Stang69's Avatar
I had wires 2 and 5 reversed. Started it up and now it doesn't stall at idle but it still runs rough. Everything in the engine seems cleaned and vacuum lines I sprayed around didn't stall out. How can I test for fuel pump possibly? Any other suggestions.
Old Jun 30, 2019 | 12:45 PM
What's the mileage..just seen it..did you gap the plugs correctly..
Old Jul 1, 2019 | 01:14 AM
MAD_MIKE's Avatar
MM Gruppe B
Have you checked your valve clearance?
Me thinks them thar exhaust valves are a bit on the tight side.
Check em every 30K miles, not 90K.
Old Jul 1, 2019 | 04:07 AM
Stang69's Avatar
The car idles about 700 RPM it doesn't stall but you can hear sputter and is burning rich. I'm not sure if the computer has to relearn so I am going to drive it today for about an hour around town and see what happens.
