Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
stuck in park and then wont shift out of first.
Old Jun 25, 2019 | 06:22 AM
vader3234's Avatar
Default stuck in park and then wont shift out of first.
Hello everyone. I'm looking for some help with my civic.
2003 Honda Civic automatic transmission 4 door ls model. Car will start but it will not shift out of park. I then use the override to be able to shift to drive. Goes into reveerse fine. I shift it into drive but then the car will not shift out first so i can drive it in first gear but stays there. I am able to manually shift to d2 and d3 and those work fine. I tested the brake switch though the brake lights do work. It seemed the switch was fine. A new one cost $8 so I replaced it anyways .I then removed and tested the shift interlock solenoid and it works. In testing the wires to the interlock solenoid I have discovered that one wire carries 12 when the car ignition is turned to the run position. The other wire however does not carry ground when the ignition is on and brake peddle is pressed. The gear indicator lights in the dash cluster work. Whatever gear I manually shift to is indicated in the dash. I have also discovered that while I'm turning the key from off to the run position the interlock solenoid actually activates for just a split second but then will not actuate when the brake pedal is pressed. Any help or direction would be greatly appreciated.
Old Jun 25, 2019 | 08:27 AM
muellersfan's Avatar
Default Re: stuck in park and then wont shift out of first.
Ask a mod to move your thread to the 01-05 Civic forum.
Old Jun 25, 2019 | 08:56 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Didn't ask, just stumbled over it and moved. Thanks.
