Check engine light overnight
Old Jun 24, 2019 | 07:35 AM
TLCBird101's Avatar
Default Check engine light overnight
A couple of days ago I was fixing up my EG hatch in my garage. I pulled it in and started working on it but didn't finish on it till the next day. The next day I turn my key and see that the check engine light wont go off and when I plug in my laptop to my s300v3 it shows a ton of corrupt values like the tps being negative and engine coolant and intake temps being 302. Not sure what I did to cause this, I already checked all the fuses, went over most of the solder joints, and fiddled with the board position a ton. All I can conclude is the back rear led (D4) says solid green during start-up, the led by the USB connector (D2) turns green briefly then turns off, and when I connect my PC it begins to flash red.
Old Jun 24, 2019 | 07:45 AM
tony_2018's Avatar
Fish Twig
Default Re: Check engine light overnight
do you have a backup of the map?
Old Jun 24, 2019 | 08:06 AM
muellersfan's Avatar
Does the engine start and run?
Old Jun 24, 2019 | 12:25 PM
TLCBird101's Avatar
Yes I have a backup map and yes the car starts but idles high
